No ACL is created on this vlan instance and port. Hence the operation to get statistics failed.
Check if there is ACL created with this meter as one of the actions. .
Warning
Failed to get meter statistics for meter %str% %vlaninst% %portinst% , as there is no corresponding ACL entry created with these parameters.
| Name | Type |
| str | String |
| vlaninst | uInt32 |
| portinst | uInt32 |
